i have a big gig comming up next wedsday for a big fair. but i'm having a problem where sometimes the track jumps back like a loop automaticly. i was like ??? i didn't even press anything. i don't know what the problem is how should i set up my options so that it doesn't happen? could it be the TCV? if so what option should i fix?
geposted Wed 20 Aug 08 @ 5:10 pm
Does it happen on more than one file? On either player? Did this just happen once, or does it happen often, and what was going on when it happened?
geposted Wed 20 Aug 08 @ 5:23 pm
yeah more than one file. only on the right player. it happens pretty rare, not all the time. and when it happened it sounds like a smooth loop. but i didn't do anything, it just did it by itself
geposted Wed 20 Aug 08 @ 6:04 pm
I'm not a TCV man, so can not help you with the options. Could it be the vinyl, like a scratch on the vinyl?
geposted Thu 21 Aug 08 @ 3:51 pm
What kind of hardware are you using? For example the CDN90 units have a habit of the drive skipping on the right player....so please tell us what your hardware set up is
geposted Thu 21 Aug 08 @ 3:54 pm
