i have a version of pro i need to download xponent plugin and it keeps asking for serial # still wont download
geposted Fri 22 Aug 08 @ 10:03 pm
You need to input your serial number. Or, if you are using the trial, pluggins are reserved for members who have purchased their software here. Hope to see you as a licensed user soon.
geposted Fri 22 Aug 08 @ 10:09 pm
There s something wrong with the mapper. The file will not open, winzip is saying there is an error, the file is also 2kb, a little small I think.
Anyone can contact the maker of the mapper?
geposted Wed 27 Aug 08 @ 11:33 am
I believe it's a small teething problem with the new website, should be fixed soon I'm sure, don't worry ;)
As TearEmUp said to willucme, you need to register your software in your profile before you can download plugins.
Regards,
Scott
Regards,
Scott
geposted Wed 27 Aug 08 @ 2:03 pm
