Is the virtual dj software that came with the Hercules rmx I just purchased the latest version? Is it virtual dj Pro? if not what are the benefits of Pro from what I have? Also is it possible to have the visual display on two separte areas and not overlapping? Thanks for the any input.
geposted Fri 22 Aug 08 @ 11:13 pm
that version is not pro. you can update to the pro version, with the pro version you will be able to play videos on a outside screen, use different pro skins jus too name a few. its worth the investment
geposted Sun 24 Aug 08 @ 4:45 am
dizzy because you already have the rmx you are/were entitled to a massive discount if you decide to upgrade to pro look here
geposted Sun 24 Aug 08 @ 5:06 am
