Hey Everyone on Virtual Dj, I would like to know if VIRTUAL Dj Can Midi with the torq exponent and how would i go about getting this to work?
geposted Sun 24 Aug 08 @ 8:29 pm
Yes, you can use the inbuilt MIDI or native support to control the xponent. Extra support is included in my mapper which is available to registered users.
Regards,
Scott
Regards,
Scott
geposted Sun 24 Aug 08 @ 9:29 pm
Thanks very much
geposted Mon 25 Aug 08 @ 5:32 am
SDBJ, How's the Exponent?
Im looking for a "all in one" unit for a second gig (with a laptop), and the Exponent cought my eye. Im also looking at the VCI-300 but its a little expensive.
Thanks!
Thanks!
geposted Fri 29 Aug 08 @ 2:19 pm
My current gig its a desktop computer with the denon HC-4500 and a X500 combo. But want to add a new very portable gig.
geposted Fri 29 Aug 08 @ 2:21 pm
Thanks!
Thanks!
Thats pretty much what I'm doing, I used to use the Xponent as my primary controller, but am currently using an HC-4500 with an Ecler Evo 5. The Xponent is a good controller with good sized well touch-sensitive jogs which are nice and loose so you can perform spinbacks etc. It's one real drawback is the lack of a microphone input IMHO.
My mapper also allows quite flexible control :)
Regards,
Scott
geposted Fri 29 Aug 08 @ 3:57 pm
In my opinion the exponent is real nice my only problem with it was the program it came with. to me the pregram is garbage, don't know how the updated version to it would be but as for now the program is trash. Now that i found out the expponent can midi with virtual i'm very happy because virtual dj is a very good software trust me. I have not midi it as yet because i'm try to get some stuff sorted out but i'm sure when i do it won't dissapoint me.
geposted Sat 30 Aug 08 @ 6:41 pm
Hey everyone i'm trying to midi virtual dj with the torq exponent and i can't seem to get it done. can anyone who knows exactly how to midi give me a hand i getting this done ihave gig friday saturday and need to get this sorted out asap
geposted Wed 03 Sep 08 @ 5:46 pm
Download the demo version of Virtual DJ Pro 5.2.
Go to config, remote control, click "Next Page", then right click the Xponent icon, and select activate.
Your xponent will now work in native mode.
To use as a MIDI device (no LED support then however), you need to disable the Xponent control above, and enable "General MIDI" instead. Then use the learning function to map the controls to functions.
My mapper can be used by registered users to provide even more functionality and ease-of-use.
Regards,
Scott
Regards,
Scott
geposted Thu 04 Sep 08 @ 8:00 am
Title now ok, is Xponent!
Some info setup is into my blog https://virtualdj.com/homepage/cioce/blogs/2751/_ENG__M-Audio_Xponent_and_Virtual_DJ_setup.html
geposted Thu 04 Sep 08 @ 8:07 am
Hey i'm finally getting the torq exponent midi with virtual and it's working well but for some reason i can't seem to get the samples set up in terms of selecting and playing them and also the effects i can't get them set up for some reason. I also need to know how do it hear the music through the headphone, i found out how to select which side i want to hear but i can't seem to hear nothing i would like to know what i have to do to be able to hear the musicon both sides and how to set the head phone cue and and volume. other than that it's working alright jus been hearing a lil distortion i don't know what thats from, maybe you all could let me know.
I LOOK FORWARD TO A RESPONSE AS SOON AS POSSIBLE BECAUSE I HAVE A GIG FRIDAY AND I WOULD LIKE TO USE IT FOR THAT.
Regards
SIANYDE SOUNDZ
Regards
SIANYDE SOUNDZ
geposted Wed 17 Sep 08 @ 6:19 am
The native mapping is not that extensive, my mapper fixes this but is only available to registered users.
The sound needs to be setup in headphones mode in Virtual DJ on the sound tab.
geposted Wed 17 Sep 08 @ 7:02 am
hey i got the headphones working but you know on the torq where it has the headphones button for you to choose which side you rather hear those button are selecting the sides because you could see it happening on virtual screen but your not able to hear either side when you press them could you tell me why that is like that
geposted Wed 17 Sep 08 @ 4:54 pm
Hey using the xponnent is awesome thanks to the mapper using vdj pro it is better than using torq software
geposted Wed 17 Sep 08 @ 11:29 pm
What do you have on the "Sound Setup" tab in the config?
You should have:
Inputs : "None"
Outputs : "Headphones"
Sounds card(s) : "ASIO"
ASIO driver : "M-Audio USB ASIO"
Output Channels : "Master : Chan 1&2 / Headphones : Chan 3&4"
Regards,
Scott
geposted Thu 18 Sep 08 @ 7:05 am
Hello Fellow DJ's & Mixers. I'm a little confused by what I see...
OK- here we go.
Looking at my Config-Info page, It shows I'm using VDJ 5.0 Rev. 6
I see the Free Download is Ver. 5.2
When I click on the CHECK FOR UPDATES, on the Info page, it says my software is up to date?
Don't get me wrong, I'm really NOT having any problems, that I feel I MUST HAVE the newest version, but. Is my software REALLY up-to-date?
OK- here we go.
geposted Fri 19 Sep 08 @ 10:14 am
OK- here we go.
OK- here we go.
I would say not, if on the Info page is telling you VDJ 5.0 Rev. 6
I would download VDJ 5.2.1 and install. There have been some new feature's implemented since that version.
geposted Fri 19 Sep 08 @ 10:18 am
I always get error in the asio sound driver and my xponet dosent work in vd?
geposted Sat 25 Apr 09 @ 2:04 pm
