If I set my NEC 1065 projector to project a 120" Diagonal image at a resolution of 1024 x 768 or 800 x 600, will a 50 ft. DVI cable maintain the quality of the picture or will I need to get a booster or use a different type of cable.
I am trying to figure out which cable to use to get the best quality picture on the 120" screen
geposted Tue 26 Aug 08 @ 2:49 pm
I am using 50ft of VGA cable at the club from my laptop and its been fine, if you were wanting to bring the cable length up to 100ft or more u may need a signal amp.
geposted Tue 26 Aug 08 @ 6:25 pm
you can run SVGA cable to 75'. DVI you can run about 20' before it looks like crapbuy a low-latancy signal amp for the DVI cable run
geposted Sat 13 Sep 08 @ 2:39 am
