hi, can anybody help choose the best external dj mixer to midi control virtual dj please, thanks
geposted Tue 26 Aug 08 @ 3:27 pm
There is no "best" controller. All of the controllers are different, and what one might like another might not like. I own the Total Control, the RMX, and two iCDXs and they are all controllers, and all different. So, I'm sorry to tell you there really is no answer to your question.
geposted Tue 26 Aug 08 @ 4:18 pm
It also helps to know what you are wanting to accomplish?
Video Mixing?
Scratching?
Ability to connect other audio devices?
etc...
Regards,
Scott
Video Mixing?
Scratching?
etc...
Regards,
Scott
geposted Tue 26 Aug 08 @ 6:38 pm
it depends what you intend to do (Mobile, club, home dj)
For mobility and costs I have used the Hercules MKII since it came out and never had an issues with it. It works very good with VDJ.
For professional use i like the Denon 4500hc because it has the same layout as dual CD players. Once you apply JP's mapper it works flawlessly.
geposted Fri 29 Aug 08 @ 2:34 pm
The one I am most happy about is the M-Audio Xponent. It's big, so the buttons are not to close, the 2 jog-wheels are big with a top touch-sensitive for scratching and around for pitch-bend. The mapper from SBDJ is very good!!. It's all in one, midi controler and soundcard. All buttons are soft-touch. And you have a UV-LED meter, not many have those.
Hope to be helpfull
Tom
Hope to be helpfull
Tom
geposted Fri 29 Aug 08 @ 4:52 pm
i am waiting for numark ns7 ;)
geposted Sat 30 Aug 08 @ 8:14 am
