Anybody had any experience with one of these and VDJ? Am just looking for a small, cheap reliable laptop to run VDJ off.
geposted Tue 26 Aug 08 @ 9:02 pm
acer extensa 4420 @ best buy...... $499 i use it 5 nights a week with timecode and video........ not one problem
geposted Wed 27 Aug 08 @ 1:14 am
Thanks, doesn't look like a bad laptop and the price is good. However it is more expensive than the Aspire One, with a lower spec. And it's bigger, so I'm not sure I could justify going for that model. I would assume that if VDJ runs smoothly on that though, the Aspire One should handle it.
geposted Wed 27 Aug 08 @ 5:37 am
Nobody else on here got any comments?
geposted Wed 27 Aug 08 @ 11:24 am
Hi sorry for my english , i have try the demo on this aspire one with 1 gig of ram , 120 gig hd , windows xp sp3..
But the only " bug " is the resolution screen.... need a skin for this lcd 8.9... 1024x600...
for BPM studio, i need to set 800x600 and openn bpm after swith to 1024x600 for best result.
geposted Wed 27 Aug 08 @ 12:17 pm
hi i have recently picked up an aspire one and have been using virtual dj for a while with a maya44 usb soundcard on my normal laptop but since ive moved over to the aspicer i went to hook it up to the set up in the club where i dj and the levels of output on both channels of the mixer where alot lower than that of which when i run my software on my older standard acer laptop! any ideas on rectifying this issue!
thanks
thanks
geposted Tue 19 May 09 @ 5:53 pm
I'm typing my reply on my Acer One right now. I wouldn't do VDJ on it. Those netbooks are not really made for that type of application. Get yourself a fully powered laptop for the best results.
geposted Tue 19 May 09 @ 8:32 pm
Running Virtual DJ on an 8.9 inch screen would be very annoying especially if you sit the notebook back past any turntables, mixers etc. I understand portablility but wouldnt it be alot more easier on a 13.1 or even better, 15.4 widescreen so that you can have more info showing on your database. I personally havent used the acer one but other online reviews also mention the "Small, oddly designed mouse trackpad".
You can fit a 15.4 widescreen laptop, Mk2 Soundcard/controller, headphones and some extra cables into one laptop backpack with some room to spare, that would be my call for portability.
geposted Wed 20 May 09 @ 1:08 am
I run VDJ (audio only) on a Samsung NC20 no problems at all. A bit slow loading tracks due to the underpowered CPU but otherways perfect.
The NC20 is a 13.1 screen which supports 1280 x 800 so it's a perfect notebook size and weight, the battery lasts for 4-5 hours too.
Excellent!
Excellent!
geposted Wed 20 May 09 @ 6:55 am
