Hi,
is anybody in here who can resize this skin to my desired resolution.
If i use the skin resizer created by dj format the skin looks not very well. Means, the turnies are not round but oval and the song display is too short.
Can someone help me?
Thankz
Thankz
geposted Thu 28 Aug 08 @ 5:04 am
Did you also try the skin resizer tool by Jeremy?
It works great.
It works great.
geposted Thu 28 Aug 08 @ 1:12 pm
I do not have 2.2 in 1440 size yet, but i do have the original version. You can try that with the resizer and just make the browser larger for now. I will try and update 2.2 in 1440 soon.
circles do not resize, i have to replace them from scratch.
https://virtualdj.com/addons/4019/turntablist%201440x900.html
geposted Thu 28 Aug 08 @ 2:02 pm
@listen2:
I'll try the other skin resizer tomorrow. i think the 1440x900 skin would help, but unfortunatelly its only the older version.
Thanks so far!!!
Thanks so far!!!
geposted Thu 28 Aug 08 @ 5:21 pm
I'll see what i can do this weekend with the resizer. If the most skin converts ok re-adding the spinners would not be to hard.
geposted Fri 29 Aug 08 @ 9:52 am
This would be really great!
The Turntablist Skin is the best one i've seen in here.
Really a good Job of you. Listen2. Thanks !!!
geposted Fri 29 Aug 08 @ 1:57 pm
