Hi all
Love the new site,
i have just bought the xponent and love it, the only problem i have is that i would like to map the play pause button as a play-stutter button and the cue as a pause stop button. could you tell me how to go about this.
Regards Dave
P.S. Keep uyp the good work
Love the new site,
Regards Dave
geposted Thu 28 Aug 08 @ 7:44 pm
Also
How Hard Would it be to map my own controls to the xponent or make a customisable mapper for it
Regards Dave
Regards Dave
geposted Thu 28 Aug 08 @ 8:33 pm
I can probably make it a switchable option.
Mapping yourself is easy in MIDI mode, but you will lose shift functions, progress bars, VU meters and LED operation.
Making an actual mapper is easy enough if you are capable in C..
Regards,
Scott
Regards,
Scott
geposted Fri 29 Aug 08 @ 9:22 am
That Would be great
thanks scott
thanks scott
geposted Fri 29 Aug 08 @ 9:48 am
I'm going to try and finish off v1.11 this weekend :)
geposted Fri 29 Aug 08 @ 11:17 am
Im thinking about creating a xponent skin in my spare time and so far you are the only other virtual dj user that i know of that uses it, what features would you like to see in it? im using mine live for the first time tonight and hopefully i should notice what the controller lacks so i can incorporate it on screen. but seeing as u have been using yours for a while maybe you will have a better insight than me.
Regards Dave
Regards Dave
geposted Fri 29 Aug 08 @ 2:10 pm
I don't really use my Xponent much any more. I also never use skins that match controllers, I have my own skin that I designed.
So I'm probably not much use on the subject ;)
There are quite a few Xponent users though...
Regards,
Scott
Regards,
Scott
geposted Fri 29 Aug 08 @ 4:01 pm
Hi,
I'm using the Xponent and I also love it. There are also two things that are nice to add to the mapper I think. Make the PLAY button a "Play Synchronized" button with an enable/disable switch, so you don't have to push SHIFT. The secund is that the bars will blink when there is only 30 secudes left on the track (like on Cd-players).
For a skin, whel, not very much to add I think. I'm using the "Compact 0.99" skin. BIG playlist screen, all the info I need. The space there is to show what sound effect you selected is small, maybe that can be bigger. Also maybe a line that shows the sample you have loaded in the first bank (the one you command from your Xponent). In this skin there is a big section for video, but I don't need that, so you will space to make things bigger.
Hope that I given some good point to think about.
later
Tom
later
Tom
geposted Fri 29 Aug 08 @ 4:46 pm
As I commented in your other post, I'll add these to v1.11 ;)
geposted Fri 29 Aug 08 @ 7:03 pm
Did you finish the skin yet?
geposted Sun 09 Nov 08 @ 7:14 am
Hi all!
need some help!
does anybody knows what command had the Dj Console STEEL, in the Mapping, for the button SHIFT? (shift - is the button that converts the 6 sample buttons, into 12)
I have now the RMX console, and I want to change the SOURCE button values, 2 do exactly what SHIFT button was doing on STEEL console.
how can I mapp it?
thank you!
need some help!
how can I mapp it?
thank you!
geposted Fri 27 Aug 10 @ 1:49 pm
