in the old version i used automix...
it used 2 decks and mixed between the decks.
in the new version it mix only in one deck.
can i change the methoed to mix with 2 decks in the new version ?
geposted Sat 30 Aug 08 @ 4:19 am
No you can't.
One deck automix is here to stay, I'm afraid. It's alot better this way IMO.
geposted Sat 30 Aug 08 @ 4:47 am
the old style was a lot better , using one deck is a problem for old computers
what is the best old stable version of this software plz ?
geposted Sat 30 Aug 08 @ 4:54 am
Using 1 deck give u a benefit of freeing the other deck for prelisten etc.
If u like this software, pls support its development by purchasing it, Thanks;)
geposted Sat 30 Aug 08 @ 8:31 am
I have not played with it but, read the manual....using the side list you can run a two deck auto mix if memory serves right.....
geposted Sat 30 Aug 08 @ 9:54 am
You can also use the auto_mixt_next action (through a short cut or dedicated skin). It will do automix between 2decks (but in this case does not use the smart mixing feature, only a simple fade).
geposted Sat 13 Sep 08 @ 1:33 am
geposted Sun 21 Sep 08 @ 6:09 pm
No, it was changed..and there are no plans to change it back that I am aware of
geposted Sun 21 Sep 08 @ 6:43 pm
