Hi all, i just installed VDJ 5.2 on my new vista pc and as soon as the main screen comes up my PC starts to exit itself.. :(
I tried like all older versions but they all have this problem. What can I do?
geposted Sat 30 Aug 08 @ 10:13 am
Is this the trial your attempting to install? It would also behoove you to register your serial number on this forum.
geposted Sat 30 Aug 08 @ 10:16 am
No it's the full version
geposted Sat 30 Aug 08 @ 10:35 am
Sounds like a conflict of some sort. Un-install all previous versions of VDJ you can find. Then google search Eusing free registry cleaner. Run it and then re-install your VDJ see if that helps.
geposted Sat 30 Aug 08 @ 10:41 am
Well please enter your serial number. If not people will persume that it's a dodgy copy.
If it is dodgy copy, then they can do things like this.
Thanks, but it didnt solve the problem.
Don´t worry, I have a legal copy, i´ll register asap.
Am I the only one with this problem?
geposted Sun 31 Aug 08 @ 10:21 am
Sounds like a conflict of some sort. Un-install all previous versions of VDJ you can find. Then google search Eusing free registry cleaner. Run it and then re-install your VDJ see if that helps.[/qoute]
Quote :
geposted Sun 31 Aug 08 @ 10:22 am
[quote]Well please enter your serial number. If not people will persume that it's a dodgy copy.
geposted Sun 31 Aug 08 @ 10:23 am
*double post*
geposted Sun 31 Aug 08 @ 10:25 am
