Hi,
does somebody know if the CDJ400 Jog-Wheel is sending Midi, and if it is compartible with VDJ?
I have read in another forum that only the buttons are sending midi.
I want to buy some CD Players and VDJ Pro soon. Can somebody recommand some Pro Players
that are compartible with VDJ, if the CDJ isn´t?
Would appreciate your postings...
geposted Sun 31 Aug 08 @ 6:49 pm
With VDJ the CDJ-400 is fully compatible. The jog works and the text info is displayed everything works very well.
geposted Sun 31 Aug 08 @ 6:52 pm
great thank you for your prompt reply, tearemup...
geposted Sun 31 Aug 08 @ 6:54 pm
About CDJ-400 from another thread:
"As stated else, latency works fairly well. Jog works fairly well although it only scratches when u have pushed down and move the jog wheel in one series of movements. Once movement has finished, the track will continue even if the jog wheel is pushed down."
- posted by Bish Wed 06 Aug 08 @ 2:11 pm
Does anybody know if this has been fixed in version 5.2.1?
geposted Wed 10 Sep 08 @ 10:30 am
i could be mistaken but that sounds like the numark iCDX
geposted Wed 10 Sep 08 @ 11:12 am
Update: I've recived an answer from support staff.
"Yes, the CDJ-400 functionality is fine with the latest version."
geposted Wed 10 Sep 08 @ 12:02 pm
