Since you can hook up two turntables to the Hercules RMX...im assuming it would be possible to hook up two CDJ's to the RMX also..but my question is would i be able to run four tracks off VDJ....two off the CDJ's and two off the RMX?...im still doing research on whether or not to buy VDJ and the Hercules so any input would be great...THANKS
j1n
j1n
geposted Mon 27 Oct 08 @ 9:56 pm
I have another question concerning the quality of the soundcard of the hercules rmx:
If you take two turntables or CD-sets how good is the soundcard working then? How huge is the delay or the lag. I am questioning whether the soundcard is able to provide a high quality in order to keep up with products like the numark virtual vinyl? Is the sound quality when sratching convincing or does it sound very computer-like?
Another thing is:
Has anyone of you tried to connect a ICDX or a Pioneer CDJ 400 to the hercules rms? How good does it work? Is the sound quality when sratching convincing?
Another thing is:
geposted Wed 29 Oct 08 @ 3:29 pm
Hey, i have something similar
but i have the numark total control, and i was wondering how i would be able to hook up time code vinyls to it or would i need to get an external sound card for it?
geposted Wed 29 Oct 08 @ 6:12 pm
I think you have to get an external soundcard...
geposted Mon 03 Nov 08 @ 8:02 am
I tried hooking up my turntables to my hercules rmx but it just didn't work. Does anyone know the right configurations ?
geposted Sun 16 Nov 08 @ 6:34 pm
I think with the RMX you have four channels but only two can be used at a time. There is a source input switch on each side so if you're looking to mix four channels at once you do NOT want the rmx as it only has the capability to mix two channels at once.
geposted Mon 17 Nov 08 @ 4:36 pm
I have a question about the RMX
my RMX freezes all the time and my maptop is better than the specs of the RMX needed
i use 2.13ghz, 3 GB RAM, 250 HDD
how do i stop it from freezing?
will a new laptop resolve this problem?
like 2.5ghz, 4GB RAM, 500 HDD and 1GB video card
geposted Sun 18 Oct 09 @ 6:40 am
I would also like to know if the RMX would work with CDJ's. Im assuming its the same as the time coded records.
geposted Tue 27 Apr 10 @ 7:13 pm
First time i see a quick and WISE move!! welcome to the Pro Level and don't mind me Im just your Friendly VDJ ROBOT !..he..he..Full of Video plugins at this point, so after you get all the ones posted here, Hit me up with a PM and I can hook you up with more!! now if you will escuse me ,I have to Re-scan my data banks...
geposted Wed 28 Apr 10 @ 6:51 am
congrats man,
i use the rmx with my dvs and i love it, although the xfader could be smoother, i like it as a mixer, check out my profile for more info and pictures,
geposted Wed 28 Apr 10 @ 6:19 pm
hi everybody,
just a little question, which timecode vinyls do i need to buy for my rmx hercules mixer and virtual dj pro??? There are so many timecode vinyls, but not all of them works with virtual dj and rmx hercules.
Can anybody help me??
geposted Tue 04 May 10 @ 9:08 am
serato ssl cv02:
http://serato.com/controlvinyl
geposted Tue 04 May 10 @ 2:21 pm
I think you can use tracktor vinyl too. I'm in the same position as you. I'm searching witch timecode vinyls co operate with VDJ. I've heard good things for serato (2nd version) and tracktor. I've also heard that numark doesn't work properly but none of these options are from personal experience so I can say nothing for sure...
geposted Wed 16 Jun 10 @ 9:10 am
I have VDJ Basic. can I use it with the Hercules RMX. Thinking about buying it for my son as a birthday present and don't want to have to buy VDJ Pro just yet.
geposted Tue 27 Jul 10 @ 9:38 pm
Sorry, it is not possible to use the Hercules RMX with VirtualDJ Basic.
VirtualDJ Basic does not support the use of any external MIDI controllers - It is for mixing using your mouse and keyboard only. Please see https://virtualdj.com/products/comparison.html
Your son can use the RMX with the VirtualDJ DJ Console Edition v5.2 that comes included free with the console. When he is ready to upgrade to Pro, he can do so at a considerable discount (Assuming that the RMX will be purchased new.)
geposted Wed 28 Jul 10 @ 8:20 am
all rmx skins need to update .we need a skin like scratch intro . rmx skins or lame all the rest of software skins look good
geposted Thu 27 Oct 11 @ 1:38 pm
Upgrade to pro and you can choose any skin you wish. I'm not sure how the le version works but I thought you could download skins?
Huey
Huey
geposted Thu 27 Oct 11 @ 1:43 pm
can hercules rmx with vdj pro work with scratch into
geposted Thu 27 Oct 11 @ 1:55 pm
If your talking about Serato's software you should probably ask on there forums........but since you asked here ill save you the hassle, NO your RMX won't work with their software.....
You can always make your own skin mimic there's, don't really know why you'd want to. I've seen and used their little program and its lacking in features but to each their own.
Good Luck
Huey
Good Luck
Huey
geposted Thu 27 Oct 11 @ 2:03 pm
i'm just talking about the colour of the beat light .i would like them to make it more colourefull like the scratch insted of just using one colour .can i used skin resizer software to had more coloure
geposted Thu 27 Oct 11 @ 2:16 pm
