Topic: BPM Problem
Hey guys, I have this problem. Im trying to analyse the BPM's on my music folder. When dloing so it will start then a few songs in it will freeze ? never had this problem before. Help ?
geposted Thu 04 Sep 08 @ 6:24 pm
I'm having the same problem. I use Flac files so I thought that maybe the issue so I never inquired about it. When I load a song to get analzyed by VDJ it will show that it's loaded in the software but on my Denon HC 4500 it remains at "loading" and freezes the software.
Is anyone else having this issue?. I've only been seeing this "freezing" over the last two updates.
I'm hoping it's a bug in the new updates.
This is messed up I never had this problem. It started when i formated my laptop and re-instaled VDJ...
Can Anyone help with this???? Still waiting, I have tried everything still nothing.
Can you explain the procedure that you are using?
Ok well im trying to analyse my music folder. I right clink on the music folder then click on analyse then any music. I t will start but then freeze after 1 or 2 songs. Am i doing somthing wrong ?
Also adding to that, For the ones that are analysed everytime i start up to program it seems that the bpm's are not been saved ? i have to redo it
As a test, try selecting a few songs in the browser, right-click, then select analyze>techno/house (depending on the version), and see how it responds. What version are you using, BTW?
Tried that, im using 4.2
What were the results?
same thing it will analyse a few songs then freeze
Does the process always freeze on the same track? If so, that track may be corrupt.
Ok thanks for the help...... But im still stuck with this problem.
If you are using a cracked version, you can expect all sorts of unusual errors. If you are using a valid copy, you should register here.
Good luck with your issue.
