I was just wondering,
Is anyone running VDJ on any HP laptops? and if so, what model do you use? I currently have a pavillion ze5375US and these are the specs:
Processor Intel Pentium 4 Processor 2.4GHz
Processor Cache 512KB (L2)
Memory 512MB DDR SDRAM (2 x 256MB) at 266MHz
Memory Max Maximum Memory 1024MB DDR SDRAM (2 x 512MB)
Video Graphics ATI MOBILITY RADEON; 4X AGP 3D architecture
Video Memory 64MB DDR SDRAM (shared)
Display 15.0-inch XGA TFT (1024 x 768) display
Wireless Connectivity Integrated 802.11b wireless LAN
Sound 16-bit Sound Blaster Pro-compatible audio
External Ports
* Three Universal Serial Bus (USB) 2.0
* One Parallel (25-pin)
* One VGA (15-pin)
* One TV-Out (S-video)
* One RJ -45 (LAN)
* One IEEE 1394 (firewire)
* One IR
Here is the problem, I am having a tough time getting video to work the way it is supposed to. There are loading issues and sound dropouts.
I have done all the tweaking I can think of doing but noting seems to work. However before anyone replies "upgrade the memory" it is already on the way. I will be maxing it out at 1GB and we'll see what that does. I am just looking for someone that is running a similar laptop to play video and what they done to get it there. Also, the other specs that aren't listed are as follows:
Maya 5.1 USB soundcard
DAC - 2 controller
SVGA projector (infocus)
Pioneer DJM 3000 mixer
CDJ 1000 MKII's
BBE 842i Proccessor
JVC GR-DVL815U DV camera (connected by firewire sometimes) for remote video
I have read the specs/requirements for VDJ but I still can't seem to get video to run smoothly.. Any help is greatly appreciated.
Thanks to all!
DJ Rage
External Ports
* One VGA (15-pin)
* One RJ -45 (LAN)
* One IR
DAC - 2 controller
CDJ 1000 MKII's
BBE 842i Proccessor
Thanks to all!
DJ Rage
geposted Fri 05 Sep 08 @ 12:24 am
That system is way under powered for video. My Sony VAIO has the same specs and it is now my music only system.
Video minimums -- 2Gb RAM and 256Mb Dedicated Video RAM -- those are the bare minimum, anything else is just going to help more
geposted Fri 05 Sep 08 @ 1:38 am
Aha! that figures. When at the International DJ Expo two years ago everything was great for running video nowadays you hafta spend 4,000.00 for a good enough laptop to do what is needed. and another 1,500 for a usb mixer. Heck I might as well go out and buy a Pioneer SVM-1000 for that price and a pair of DVJ-1000's.... (note* prices listed below are rounded to nearest hundred $)
Price for VDJ rig = $8,900.00
Price for Manual Hardware = $10,000.00
for an additional $1,100.00 it seems the best way to go is with pioneer. Not that I am bashing VDJ. It just seems that the most cost effective way to do video is the hardware route. Although, I have to admit it was a decent way to have 6 decks at one time (which is great for drum & bass).
Thanks for the input Cstoll, it was VERY enlightening.
geposted Fri 05 Sep 08 @ 3:08 am
Well you can get those specs in a machine for lest than $2000
And things change with time especially in the world of computers
-- your system can do it, it will be very sluggish and almost unbearable...
That would be called SSL+Video not VirtualDJ
geposted Fri 05 Sep 08 @ 10:25 am
