http://www.hercules.com/uk/DJ-Music/bdd/p/69/mobile-dj-mp3-black-/
If so then is this any good to buy???
geposted Fri 05 Sep 08 @ 2:11 am
Can any body let me know because if it is I would like to get it soon so I can start learning more about DJing.
geposted Fri 12 Sep 08 @ 4:44 am
afraid not, but if you buy say the hercules rmx you will be eligible to a nice discount if you upgrade to vdj pro, a similar offer also applies to some numark products.
geposted Fri 12 Sep 08 @ 5:17 am
the hurcles DJ control MP3 comes with a limeted version of VDJ and its about the same price, a good starter console but you will need 2 soundcards or a 5.1 card to preveiw in headphones as it doesnt have a soundcard built in.
geposted Fri 12 Sep 08 @ 6:29 am
Yeah, I'd stay away from cheap wireless products like this, just like with those cheapo wireless headphones & mics you can expect alot of radio interferance. DJ Control MP3 if you don't need a soundcard, MK2 if you need a sound card but on a limited budget, after that the RMX. There are also better but more expensive controllers from other companys'^]
geposted Fri 12 Sep 08 @ 6:51 am
So stay away from this and get something else
Or go with this??? If so where can I get a soundvard and w/e else I need???
geposted Sun 14 Sep 08 @ 9:38 pm
personally i havent used the mobile DJ but as its wireless theres got to be a delay and personally if its connected direct to USB then its the fastest way possiable. whats your budget? if it is only 60 - 80 then get the DJ control MP3 and a cheap USB soundcard if thats all you want to do.
BUT do you want to get into timecoded vinyl or CD's? cause if you do then youll need a ASIO soundcard (low latency) and the Hurcles MK2 has this built in so you dont have to worry about buying another soundcard to preivew or to go into timecoded vinyl or cds! ive found it for about 140 (http://www.pixmania.co.uk/uk/uk/632682/art/hercules/dj-console-mk2-sound-card.html) or play.com do it with free shipping but its out of stock. and for the extra personally id get that!
I have a DJ console MP3 and personally i wish id got the MK2 as im now starting to go into Timecoded vinyl (6 months down the line!) so now ive got to buy a MAYA44 and sell my DJ console!!! it all depends where you want to go but rember BUY CHEAP BUY TWICE! as your skills will improve and theres only so much cheap hardware can do wether its cheap decks or consoles.
I hope this helps u if u need any more help just post n reply 2 what ur goin 2 do!
geposted Mon 15 Sep 08 @ 2:53 am
Well I want to get into remixing other soungs like adding my own beat to hit all that. I just want to be doing it right the first time. I am willing to spend about $200 but would like to find something for less.
And that link didn't work.
But I really want to be able to do everything @ home and I don't really have much space where I live so that's an issue.
geposted Mon 15 Sep 08 @ 11:50 pm
If any of you can help me any more feel free to add me on myspace:www.myspace.com/lpkzach92fu or email:lpkzach92@yahoo.com
geposted Tue 23 Sep 08 @ 1:03 am
I would say look into numarks total control. Stay away from wireless things.
geposted Tue 23 Sep 08 @ 3:52 pm
or save up just that little bit longer and go for the rmx...
geposted Tue 23 Sep 08 @ 4:00 pm
So just stay to the basic shit.
Y does wireless suck so much???
geposted Thu 02 Oct 08 @ 12:41 am
Wireless sucks so bad beacuse there are many people at parties with cell phones, at house parties there is the microwave and other wireless products, there are always problems with inexpensive equipment for Professional DJs.
If you want to go Pro, get pro equipment. If this is ok for you then the RMX is great. A PC/Laptop, RMX, and powered speakers. Thats it!
geposted Thu 02 Oct 08 @ 1:00 am
Yeah I would save up a bit longer and go for the RMX works a treat for me, to be honest the one your looking at looks as if it would be easily damaged, very plasticy (is that a word?).
Save yourself the nightmare of having so many issues, it just may take a little longer to get there mate.
geposted Thu 02 Oct 08 @ 3:53 am
So RMX,Mac/PC, and speakers and I'm set???
Also is VDJ the best program to use???
geposted Sat 11 Oct 08 @ 1:14 am
