I have a maya 44 sound card for my time coded set up and I will be getting a vci-100 soon because I like how portable it is. I was wondering if I could use the same time card for both. If I had to guess I would say I could because the computer only reads the sound card and not the turn tables but I would like to make sure. Thanks.
geposted Sat 06 Sep 08 @ 2:15 pm
Yes you could use your Maya with the VCI100
geposted Sat 06 Sep 08 @ 2:27 pm
What about a vci-300. I know it has a built in sound card so could I just unplug the maya 44 when I want to use the vci 300. Or can you not do that. Thanks for the reply by the way.
geposted Sat 06 Sep 08 @ 2:34 pm
