Hey all (cross post from hardware section)
I have the timecode setup and its pretty much working correctly, however i can hear the timecode cd come through my speakers!!
any idea on how to stop this?
thankms :)
thankms :)
geposted Sat 06 Sep 08 @ 10:55 pm
What kind of soundcard are you using?
geposted Sat 06 Sep 08 @ 11:12 pm
behringer UCA202
geposted Sat 06 Sep 08 @ 11:22 pm
nobodies had this issue?
geposted Sun 07 Sep 08 @ 4:42 am
Practically, u would not want to use the behringer uca as even tho it may be used to control only one deck (timecode) at a time. It is use more as simple audio interface to connect mixer to computer. It has only one stereo input n one stereo output.
I would suggest if u looking for better tool, look for hercules console or maya44usb etc. Of course there are more high end card for this;)
geposted Sun 07 Sep 08 @ 6:31 am
hrm.. not really an answer to my question tho...
isn't the only difference between the MAYA and the UCA that the mayer is 4 channel?
how/why would this affect the time code cd noise?
geposted Sun 07 Sep 08 @ 7:35 am
you just have to disable the monitor (pre-listen) of the inputs.
geposted Sun 07 Sep 08 @ 11:38 am
ok..
disable the monitor? how do i do that
geposted Sun 07 Sep 08 @ 5:14 pm
Somewhere in a control panel you can disable it. Don't ask me where, i don't have that soundcard.
geposted Mon 08 Sep 08 @ 4:16 am
I have the UCA2000 that came with the xenyx series.
And I dun think there is the control panel there for the UCA unless there is for ur model.
That y i said it just a "simple" audio interface.
geposted Mon 08 Sep 08 @ 4:48 am
ok..
does anybody know where?
geposted Tue 09 Sep 08 @ 11:43 pm
But what about the "ASIO Error;Not Enough Channels"? Cause I'm having that problem too.
Thanks, and sorry to bust into your conversation.
Robb
Robb
geposted Wed 10 Sep 08 @ 1:27 am
hi new hir. actuaaly im an mc. and im trying to be a dj hehehe. i have a lop top working with vista. and a vdj. with cmx 3000. player. im planning to get uca202 coz that was the only thing available hir... any one know how can i use two uca202 to be able to controll both channel with tym code cd. hope u can help me guys. tnx.
geposted Thu 23 Oct 08 @ 7:31 am
