Hi,
I've got some Torq vinyls, I didnt downloaded and installed VDJ,
because I dont want to blow the 20 days trial. I would like to know,
if Torq vinyls work with virtual dj ?
«I know there are two vinyl modes, I dont need the needle drop one...»
If not, thats ok, I can purchase some Numark Virtual Vynils and test
the system.
So, if thats the case, buying from Virtual Dj dot com. Where r the items
being shipped from? Europe? Please let me know, because of shipping
issues.
Thanks for your time.
the system.
issues.
geposted Sun 07 Sep 08 @ 9:13 pm
No, Torq vinyls are not compatible.
If you can get VirtualVinyl vinyls - what more would you need from VirtualDJ other than a license?
If you decide to buy, then the purchase is a download file so, no shipping necessary. What else were you looking to get from here ?
geposted Sun 07 Sep 08 @ 10:54 pm
Hi,
thanks for your atention!
Theres no problem about purchasing the license directly from vj dot com.
My question is diferent, its about the Vinyls. I would like to know, where to
get the original vinyls from Virtual DJ. Since I may get them on a european
music store, probably numark ones, I would like to know, if I could get
from Virtual DJ instead, in case, its being shipped from Europe.
So, my question is, where are the items being shipped from? Where's Virtual
Dj located?
Dj located?
geposted Tue 09 Sep 08 @ 11:09 pm
We have distribution in Europe and the US. So you would get them from Europe. And the VirtualVinyl are the same as VirtualDJ timecodes. They are one in the same just labeled different.
geposted Wed 10 Sep 08 @ 5:33 am
If you place a order for the Vinyls, they get shipped from the UK. It took 3 days to receive mine, but I live in the UK.
Virtual Vinyls one's you should be able to get or order from your local Numark agent.
geposted Wed 10 Sep 08 @ 5:54 am
Not sure but i thought Virtual DJ supported MS pinkey? Torq Vinyls are these rebranded.
Numark Vinyls can be purchased from any Numark Dealer find your nearest store on www.numark.com
geposted Fri 19 Sep 08 @ 3:31 pm
