Can anyone help me... Everything runs smoothly on VDJ 5.2, and with video, I can mix up and mash up videos, no problems. but when i try to record, it says Codec Missing (PC). My Mac is similar, but instead, it thinks it's recording - but the MOV file just shows a static image. I checked the config, and it says the codec is JPEG - which explains. Can anyone tell me which codecs I need to install on either PC or Mac?? Thanks!
geposted Mon 08 Sep 08 @ 8:31 am
