i just instaled virtual on my laptop and how do i configure it so i can hera what m i mixing in my headphones and have mix play on speakers....i have a normal dj setup and im looking forward to use my virtual dj as well but i cat set it up do i need additional sound card
please help me !
THX +D
please help me !
THX +D
geposted Tue 09 Sep 08 @ 1:07 am
If you only have one headphone jack, then you are going to need a USB sound card.
ESI Maya44, M-audio Conectiv or Numark DJ|IO.
Look on the Hardware tab of this website, under Products, also.
geposted Tue 09 Sep 08 @ 1:22 am
you will need a second sound card, but in the mean time you could try this just to get you started...
basically if you cant follow the clip
go to config
soundsetup
outputs > external mixer
soundcards > mono seperated
output channels give you white lead/left channel red lead/right channel to your mixer
you will have to use a y splitter for each channel to get dual inputs into mixing desk
which of course will only give you mono sound output
geposted Tue 09 Sep 08 @ 2:44 am
