Sup guys,
I'm getting this message when i try to install VDJ in my second Laptop
Invalid skin file (error line % in the xml)
Any Help will be appreciated
Thanks
Thanks
geposted Tue 09 Sep 08 @ 12:22 pm
Hi there, try to reinstall it. It should be ok;)
geposted Tue 09 Sep 08 @ 3:29 pm
Thanks Spinna got that sort out. Now when i try to configure time codes and i select the external sound card (I'm using conectiv) it crashes. Also cpu is way up there like 50-60 during playback with Laptop internal card. I'm new with Mac so any input will be greatly appreciated.
Thank You
Thank You
geposted Tue 09 Sep 08 @ 8:22 pm
Unfortunately, timecode only works with the Virtual Vinyl sound card or the Hercules RMX controller. This has been an issue since VDJ has dropped. VDJ support says that it's a problem with the aggregate device and they're working on it. Hopefully full timecode support will be with us soon. There is no time frame for this. So, the best advice is to wait patiently.
As for the CPU issue... it's been said if you go to settings/codecs and change the default audio decoder to the quick time decoder it helps.
Good luck!
Good luck!
geposted Tue 09 Sep 08 @ 9:32 pm
Thank you very much!!! HiTower
geposted Wed 10 Sep 08 @ 8:20 am
hello, I just updated to pro edition but i can't instal it in my mac if somebody know how to do it please let me know
geposted Thu 11 Sep 08 @ 5:45 am
Hi leonard, installing on mac is easy. Just open the application and it will self install. Pls tell in detail what problem u encounter. Thanks:)
And last and not least, welcome to the mac community and as a pro user;)
geposted Thu 11 Sep 08 @ 6:20 am
hi.. im tryng to install virtual DJ on my mac book but when i open the file it says choose a file to open with and im not sure how to get it open and start installing ...
geposted Tue 27 Jan 09 @ 9:39 am
