Anybody else have problems with the way the fader moves in VirtualDJ when using a Numark Total Control.
It acts kinda jerky. The right volume fader is ok, it's just the left one. The work around is to leave both of the faders up and use the crossfader, which is working great.
I just installed the new firmware. I don't think it was that because it was doing it before that. Anybody else notice this?
geposted Wed 10 Sep 08 @ 1:32 am
Wow....
Nobody else has had this problem?
geposted Tue 16 Sep 08 @ 8:52 pm
Try to contact Numark Service ;)
geposted Wed 17 Sep 08 @ 2:39 am
djchris73 wrote :
Wow....
Please contact Numark Support or me directly if you have skype : NumarkSi
geposted Fri 19 Sep 08 @ 3:13 pm
Simon,
I opened a ticket with Numark, posted it in the Numark Forums and I sent you a Skype message...
geposted Tue 23 Sep 08 @ 7:36 pm
Just wanted to add to this thread that the jerky, seemingly "possesed" fader is the left screen/software fader...
Not the physical one on the actual NTC...
Physical/hardware faders are very smooth.
I don't think the problem is mechanical or the VDJ software. I think it's in the "soft" portion of the NTC...
Here's a link to the Numark forums' thread wher this also posted:
http://forums.numark.com/showthread.php?t=2873
geposted Tue 23 Sep 08 @ 8:23 pm
Are you using the mapper?
geposted Sun 28 Sep 08 @ 6:28 am
i've been trying to find an earlier post i made regarding the same topic
can't find it
new search engine sucks :-(
anyway
as i remember
i had the same kind of problem
i sent mine back
got a new one
problem gone
can't find it
anyway
as i remember
i sent mine back
got a new one
problem gone
geposted Sun 28 Sep 08 @ 6:52 am
I fixed the problem. It was mechanical. My co-worker noticed that the issue went away when he held the Total Control upside down. Don't ask me to tell you what made him turn it upside down.
I opened it up and reseated the connectors associated with the PCB that had the Channel faders soldered on. I buttoned it back up and it worked like a champ.
geposted Sun 28 Sep 08 @ 4:41 pm
No. why?
geposted Sun 28 Sep 08 @ 4:43 pm
