I was testing out the latest version of VDJ on my computer last night and discovered a new problem that I can't find a discussion on.
When there is a video playing, I notice when I type something in the search bar, the video will freeze for a millisecond and then keep playing.
Similar to the loading issue that was once a problem in previous versions
I have the decode while hidden button checked in the settings, so I am not sure what could be creating a problem.
This is a rackmount computer that we had built 3 months ago. It should be more than fast enough for VDJ application
Specs are as follows
This is the video card
ASUS EN8800GT/HTDP/1G
NVIDIA® GeForce 8800GT
PCI Express & PCI Express 2.0 support
Microsoft DirectX 10 and Shader Model 4.0 support
OpenGL®2.0 support
HDCP compliant
PCI-Express 2.0
HDTV-out
DVI * 2
D-Sub
HDCP compliant
This is the motherboard
Intel® Desktop Board DP35DP
specs are here...
This board has 8gbs of RAM
This is the processor
Intel Core 2 Quad Q6600
OpenGL®2.0 support
HDCP compliant
PCI-Express 2.0
HDTV-out
DVI * 2
D-Sub
HDCP compliant
specs are here...
geposted Wed 10 Sep 08 @ 8:18 pm
