Hi can anyone help I am just starting out mixing but do not have a mixer yet can anyone suggest a good but cheap mixer to start out with that works with VDJ. I am running VDJ version 5.2 and Windows Vista Home Premium with Intel core 2 duo 1.66Mhz 2.00 Gb ram
geposted Thu 11 Sep 08 @ 10:27 am
You should register your VDJ.
Your mixer depends on what kind of DJ'ing you want to do and how you want to DJ (straight off the computer, Timecode c.d or wax, controller) Do you need a soundcard? Do you need a 4 in 4 out soundcard?
But the 1st thing you should do is register your software because dj'ing on cracked software can cause BIG problems. You have unlimited updater when you register and can download skins which may help you as well as effects, mappers, samples and more.
geposted Fri 12 Sep 08 @ 3:16 pm
I currently have a sound card and a numark dxm-06 which has some nice effects and is relativly cheap, i got mine used on ebay for $150.
although now i'm considering getting a controller and using that to controll the built in mixer with VDJ which also gives you the ability to control loops and cueing easier than just your mouse. also if you haven't accually bought VDJ you can get a discount if you upgrade from the vertions that come with some controllers, which i'm considering.
geposted Fri 12 Sep 08 @ 8:56 pm
the hercules dj console rmx is pretty good, it's not the best but for a beginner it's sound
geposted Fri 12 Sep 08 @ 9:33 pm
