processor amd 64x2 windows vista.....need to know what drivers i need to install and what do i do after i dl the driver like where do i put it....also is there any way i can set up virtual dj to shuffle songs or go play one whole song and shuffle to the next like in i tunes
geposted Thu 11 Sep 08 @ 4:43 pm
processor amd 64x2 windows vista.....need to know what drivers i need to install for a maya 44 soundcard and what do i do after i dl the driver like where do i put it....also is there any way i can set up virtual dj to shuffle songs or go play one whole song and shuffle to the next like in i tunes
geposted Thu 11 Sep 08 @ 11:21 pm
you can find the drivers below
http://download.esi-audio.com/?w=esi&p=40&g=2&l=en
follow the instructions through the installation
(unplug maya, run the setup, you will be asked to plug-in maya etc...)
one more thing
very important !!!
the maya soundcard will be only recognized the right way(asio)
only on the usb port you installed the drivers
if you wanna switch usb ports
you have to reinstall the drivers on that port
if you wanna play/automix songs like other media players
just go to the automix options > automix type > and select "none (back-to-back)"
hope this helps,
matt
one more thing
very important !!!
hope this helps,
matt
geposted Fri 12 Sep 08 @ 4:15 am
geposted Fri 12 Sep 08 @ 4:35 am
ok i installed the driver it works...whast wrong now is i have a nuemark 3 channel mixer and it says that asio sound driver doesnt have enough channels.....btw are there any mappers for the nuemark dxm09???
geposted Fri 12 Sep 08 @ 3:21 pm
