I am wondering how do to a clean wipe out of my muisc data base - then a rescan. . . I looked through the manual and either didn't see it or it's not in there.
any help is most welcomed.
geposted Thu 11 Sep 08 @ 6:28 pm
I don't understand why you would want to do that but...
If you want to wipeout the entire database you go to the database and delete it. when you open VDJ again it will create a new database from scratch.
If you want th wipeout the search database, simply rightclick on the drive you want to delete, then click delete. You can then rescan that drive.
Hope this helps.
Hope this helps.
geposted Thu 11 Sep 08 @ 6:59 pm
djcity wrote :
simply rightclick on the drive you want to delete, then click delete..
It will delete the entire contents of the drive.....
geposted Thu 11 Sep 08 @ 7:02 pm
What about, just doing a Re-scan.
geposted Fri 12 Sep 08 @ 2:24 am
Oops...
Tearemup is right.
I meant remove from search database.
Sorry dude. I'm glad Tearemup is around.
Thanks
Tearemup is right.
Thanks
geposted Fri 12 Sep 08 @ 2:55 pm
