i have 2 technics 1200's
vestex o5 pro
virtual dj software
what do i need to get to make virtual vinyl work on my set up?
vestex o5 pro
virtual dj software
geposted Fri 12 Sep 08 @ 12:27 am
Well first off all you need to register your copy of VirtualDJ
You will need a soundcard with 4 inputs and 4 outputs, such as a Esi maya44, this will allow you to connect your turntables to it.
Then you will need to order a set of VirtualDJ Timecoded Vinyls from this site. Or your could order a set of Numark timecoded vinyl (there the same as ours) from your local Numark agent.
Put all this together with a few RCA's and you are good to go.
geposted Fri 12 Sep 08 @ 2:37 am
