i just got this controller 2 days ago i been playing with this and everything works fine with the native support
but i cannot see the text or the led in the controller.
im using a mac 10.4.11 THANX
geposted Fri 12 Sep 08 @ 3:32 pm
ione more thing when i use the 4500 with reflex the software thhat comes with the controller everything works perfect i can see the lights and the text, but i want to use it with vdj help please
geposted Fri 12 Sep 08 @ 3:38 pm
Did u update the firmware on the controller ?
Follow this link http://www.denondj.com/plugin.asp?prod=DN-HC4500
geposted Fri 12 Sep 08 @ 5:26 pm
if you are using the latest version of vdj, I would say after you activate the controller in remote, you should be good if your firmware is current.
geposted Fri 12 Sep 08 @ 10:57 pm
