i am running vdj 5.0 on a dell laptop,2 numark icdx cd players i hook them up on hid mode, i use a numark dj io soundcard.my problem is when im playing music i keep getting skipping or stuttering when im loading a track on the opposite deck? this is very annoying espically when playing in front of an audience.please help
geposted Sat 13 Sep 08 @ 1:40 am
What spec is the laptop?
Audio or video?
Whats your CPU utilisation whilst loading a track?
What ASIO latency is your DJ IO control panel set to?
What do you have set on the sound setup and performance tabs in VDJ?
Regards,
Scott
Audio or video?
Regards,
Scott
geposted Sat 13 Sep 08 @ 7:12 am
its a dell 1525 with 3 gigs of ram..ihe soundcard is set to 23m's master tempo fast,safe mode off
geposted Sat 13 Sep 08 @ 11:38 am
Had the same problem until I disabled McAfee and WIFI. Download DPC latency checker. It helped me alot. No issues at all. It may help to create a separate hardware profile to use for just VDJ.
geposted Sat 13 Sep 08 @ 9:30 pm
