hi. i cant browse my videos in the same way i can see my audio library. i have to drag the file itself into VDJ. as soon as any file is associated with video, it disappears from my browser... am i missing something really obvious?? also, could anyone tell me the best screen capture software for recording video mixes on PC? Thanks!
geposted Sun 14 Sep 08 @ 5:07 am
are all your codecs upto date and do you have the latest version of directx installed.
forget about screen capture software if you are wanting to record your mixs, use an external dvd recorder if possible for best results.
geposted Mon 15 Sep 08 @ 4:20 am
thanks tayla. i will give these things a try. i think my codecs are up to date, but to be honest, i don't know which specific codecs i need for video. there's so many bits and pieces, i get confused. and yeh, i'l try DVD recording, the screen capture software seems lower fidelity, like it's skipping frames or something. maybe direct x is what's needed... thanks again
geposted Mon 15 Sep 08 @ 3:59 pm
