Forum: VirtualDJ Skins
Topic: Tiny skin (1024x600) for Netbooks
Has anyone designed a tiny skin for AtomicMP3 that would fit on most recent netbooks having a display resolution of 1024x600 ?
I am using AtomixMP3 on a Medion Akoya E1210 netbook with a 10" display. The default skin can be displayed, but I would love to use more sophisticated skins such as the Denon Black (but this one is for Virtual DJ).
I use an external USB Sounblaster X-Fi Surround 5.1 for the main sound, and the netbook headphone jack for monitoring.
All set with merely 1.5 kg of Hardware !
geposted Sun 14 Sep 08 @ 9:42 am
dos anybody have a skin size 1024x600 thanks
You can only download non-standard skins once you have purchased VDJ Pro.
I would guess not, as AtomixMP3 is a very old program and 1024 x 600 is a relatively new native resolution.
Apart from that, you would only be able to download custom skins after registering your serial number.
Keith
Thanks for the skin. This (1024x600) is what I need for my netbook. Tired of scrolling.
Im going to be blunt here, but thanks for which skin?
There is no skin for AtomixMP3 in 1024x600.
and there are no skins here that Non Licenced Users can download.
Registered users can download from virtualdj.com/addons/skins.html
Also as mentioned above, AtomixMP3 is now an old program and is nolonger being deloped anyfurther, however dont let this put you off, as i have it installed on my netbook, so i can use it for MP3s.
