I am having a problem with the latest version of VDJ
Something started happening with VDJ 5.2.1 on my computer.
I just installed the midi map for my Pioneer players and when I load a track into a player, the current song playing will start to stutter for about 2-3 seconds and then continue playing.
I am not sure what is causing this. I have the latency set all the way down to performance and there is no Anti-Virus or major applications running in the background
It does not happen on every song when loading, but a lot of them.
I was going to re-install VDJ, but wanted opinions if I should try something else first.
This is a rackmount computer that we had built 3 months ago. I is way more than needed for VDJ, so it should be more than fast enough for VDJ application
This is the video card
ASUS EN8800GT/HTDP/1G
NVIDIA® GeForce 8800GT
PCI Express & PCI Express 2.0 support
Microsoft DirectX 10 and Shader Model 4.0 support
OpenGL®2.0 support
HDCP compliant
PCI-Express 2.0
HDTV-out
DVI * 2
D-Sub
HDCP compliant
This is the motherboard
Intel® Desktop Board DP35DP
specs are here...
This board has 8gbs of RAM
This is the processor
Intel Core 2 Quad Q6600
specs are here
OpenGL®2.0 support
HDCP compliant
PCI-Express 2.0
HDTV-out
DVI * 2
D-Sub
HDCP compliant
specs are here...
specs are here
geposted Tue 16 Sep 08 @ 8:13 am
PROBLEM SOLVED!!!!!!
Turned out to be a midi control that was mapped to do three different things at one causing a conflict
geposted Wed 17 Sep 08 @ 2:13 pm
