Hi,
I am runing Numark Cue 5.2.1. Some songs dont show up in my folder, despite them being on my computer. Confirming this by searching window. I have tried to re add the folder into my search pattern.
Is there a reason for this? Or anything i can do?
I also tried to fix/clean the browser using the function in the software.
I am running windows Vista and this only started when 5.2.1 was installed.
geposted Tue 16 Sep 08 @ 11:04 am
The quickest and simplest way is to do it, is to right click on the drive or folder (from the browser tree) and select the 'Add to Search DB'
geposted Tue 16 Sep 08 @ 11:27 am
Jimmy B, thanks. But i tried re adding the folder. Still no luck.
Any one else?
Any one else?
geposted Tue 16 Sep 08 @ 11:37 am
Is there any pattern to the songs that don't show up - a certain filetype, characters in the name etc?
geposted Tue 16 Sep 08 @ 12:05 pm
ill check tonite and get back to you guys.
geposted Tue 16 Sep 08 @ 12:22 pm
no there is no common symptom...
very weird
very weird
geposted Wed 17 Sep 08 @ 7:47 pm
Try this:
Remove the songs from db and close VDJ. Open the folder where the songs are and rename them. ex. if the mp3 filename is:
01 Unkown artist-unkown song.mp3, change it to: Unkown artist-unknown song.mp3
I dont know how your filename looks but i think you know what i mean.
Now start the VDJ again and add the songs to db.
geposted Thu 18 Sep 08 @ 1:52 am
that worked!
thanks man
thanks man
geposted Thu 18 Sep 08 @ 8:26 am
that worked!
thanks man
No problem. Glad i could help :) Hade the same problem when i was trying the trail version.
thanks man
geposted Thu 18 Sep 08 @ 12:56 pm
This happened to me.
Could not find by title but showed up when search by artist.
It's quite annoying.
Using 5.1
Using 5.1
geposted Sat 04 Oct 08 @ 11:13 pm
