im having trouble setting up my timecoded Cd. can someone please show me
geposted Thu 18 Sep 08 @ 4:31 pm
This is how you set it all up. Just replace the mk2 with your soundcard.
Thanks to spinnaJ
Basically one CD player goes to input 1&2 of your soundcard, the other goes to input 3&4 of your soundcard.
Then output 1&2 of your soundcard goes to channel 1 of your mixer, output 3&4 of your souncard goes to channel 2 of you mixer.
In VirtualDJ Config>Sound setup tab set as follows.
Inputs: x2 Timecodes
Outputs: External Mixer
Soundcard: Asio Icon
Soundcard(s); your soundcard.
Hope that helps.
Thanks to spinnaJ
Hope that helps.
geposted Thu 18 Sep 08 @ 7:27 pm
Ur welcome Jimmy n thanks to u too..hehe;)
@babyfez420
What type of cd player r u using btw? N soundcard?
@babyfez420
geposted Fri 19 Sep 08 @ 3:26 pm
im using torq connectiv and 2 gemini cfx
geposted Sat 20 Sep 08 @ 12:10 am
Ok set it up n use the consumer timecode cd that can be downloaded here. In the config once u have everything hooked up.. u can just press the auto config couple of times n try it on smart mode first.;)
U using total control too in ur set up??
geposted Sat 20 Sep 08 @ 6:30 am
ya i have the total control set up.. for some reason when i start scratching it sounds squeecky
geposted Sat 20 Sep 08 @ 7:14 am
Ok i can't comment on the total control side;)
So have u sort this?
geposted Sat 20 Sep 08 @ 4:22 pm
well the main problem is that the signal is lagging a bit. when i hit stop or pause it doesnt right away. is there any special set up where it wont lag?
geposted Sat 20 Sep 08 @ 9:52 pm
What version of VirtualDJ are you using, and if your are using 5.1 or above what timecode engine are you using,
You have a choice of 2 you could try.
geposted Sun 21 Sep 08 @ 3:43 am
Set latency to auto in performance tab.
geposted Sun 21 Sep 08 @ 6:18 am
