Hi,
got a nasty problem. My VDJ is taking up allot of CPU when it's idling (from start to end)..
In the task manager it say's about 70-80%.. It never has been like this before, what's wrong?
Thanks
Thanks
geposted Sat 20 Sep 08 @ 4:22 pm
Have u installed any software lately?
geposted Sat 20 Sep 08 @ 4:23 pm
Nope.. don't got any cracked or spyware'ed programs here... And everything else is doing good... Only VDJ that has this issue. I've tried to uninstall and install again, but same problem...
geposted Sat 20 Sep 08 @ 4:29 pm
What is ur system spec n what OS are u using?
geposted Sat 20 Sep 08 @ 8:04 pm
win xp, all latest update
3ghz CPU
1GB RAM (should have some more, but this is not the issue now)
radeon x1650 pro
audigy 2 soundcard + internal 5.1
the wierd thing is that it's only vdj acting strange... like it's scanning songs without actually doing it.... no other programs
3ghz CPU
radeon x1650 pro
geposted Sat 20 Sep 08 @ 9:13 pm
Do u have norton install? if so uninstall it n use avg instead. Also what skin do u use? Can u try to use the default and see if it act the same.
geposted Sun 21 Sep 08 @ 6:16 am
Maybe you have a conflict somewhere on you system, that's causing the high CPU usage
geposted Sun 21 Sep 08 @ 6:20 am
There could also be apps running in the background you cant see. Try CTL/ALT/DELETE )Task Manager) and click on processes. I only have @ 40 running on both my desktop and lappy....
geposted Sun 21 Sep 08 @ 7:11 am
No offence, but I got good knowlegde of computers :)
All other processes and services are running normal. It's just VirtualDJ.exe that's going bananas...
I'm using the new standard skin that comes along from ver. 5.1 and I've tried to change that aswell, no luck here either.
As I've said before I've also has tried to resinstall without succsess. Tried to restore the factory defaults --> fail.. I can't figure this out..... next step would be to format my computer and reinstall windows..... AWWW I hate this!!
geposted Sun 21 Sep 08 @ 11:09 am
Before u gonna reinstalled... can u answer me this. Sometime different skin can have that effect as i remember.. only trying to help;)
geposted Sun 21 Sep 08 @ 11:18 am
I know you do, that's why I love u mate, lol :p
I will try some other skins and test various things, and I'll get back at you
geposted Sun 21 Sep 08 @ 11:20 am
haha,..yeah try to find the problem n only at the last resort a reinstalled is ok;)
geposted Sun 21 Sep 08 @ 11:30 am
