Forum: VirtualDJ Skins
Topic: Midi Skin
geposted Sun 21 Sep 08 @ 8:19 am
Pls look at my blog.
Regards;)
nksouljah wrote :
i was wondering if its possible to get this "Midi" Skin as a zip file for Mac.
https://virtualdj.com/addons/4190/MIDI.html
will there be a version with 1280x800 solution?
bigup!
Thanks, for the little difference in the size 768--->800 just click the maximize button
Now available also for MAC ;)
wicked :)
thanks a lot i really like this skin
it looks a little like serato itch ;)
is there a hidden maximize button or do you mean the fullscreen button?
in fullscreen mode i still can a part of my desktop in the background
Maximize skin function of VDJ can't work 1280x768 to 1280x800 pixel, a down zone of the desktop can't be hidden.
A possible solution to resize @ 1280x800 is with JeremK tool but it work only on PC.
Ah right, i guess since this is a bottom designed skin that possibilty was not an option, had the browser been on the bottom section the maximize button would work. I know a user had done that before on another skin i did.
The issue i had on a different skin was that the section right below the broswer was used in a pannel, so if i wanted to extend it to 800 i then would have to move and recode the pannels, i felt it was not worth all that for 32 addition lines, but that is from a guy who likes his taskbar ;) MIDI is a little different since it has a upper browser section.
I like this skin :o)
but why do you split the wave forms ? Is it possible to change it to like the default wave forms?
Or is ist possible to remove the wave display in the bottom line?
[Well when i got the idea for the skin i decided that some times when i am scratching i cant clearly see the cue points on the screen, so basically the splits provide a clear view of each track. However the reason i was drawn to VDj in the 1st place was the overlapping waves and the ability to beatmatch without listening so i wanted to have the "normal" view but only to verify the mix, you dont really need to see the entire wave like in default skins. ]
I like the skin too, but I would like to see the Waveform, spinners and info at the top and the broswer in the "normal" positons.
I've tried to do it myself but it all went tits up :(
Would anyone care for a skin update??/ i could add keys and camalot displays and anything other suggestions as long as we keep it minimal and not ruin the layout. ;)
Yes I would mate, and may be move a couple things around, but keep it minimal.
I can just remove the split waves from the bottom without having to shift all the other things around. Sort of a ghetto solution but it would do the trick. I then can get to shift everything down. I wonder if Jerm's skin resizer can simplify that?
Sounds good listen2
