Topic: How do you.....?
If you move tracks around on a drive how do you get rid of the bad searches? Almost all of my songs error when loading them because I have moved them on the drive.
So how do we do that. I skimmed over the manual but didn't go in depth. I figured you guys would know.
geposted Tue 23 Sep 08 @ 8:29 am
you could try delete your library and then rescan your laptop.i takes time but works sweet.
No. Just use the Check and Clean utility from the Config -> Browser tab
Go back to the manual Paulie and look in the Config->Browser tab for explanation of what the utilities do
the "check, clean, fix" STILL doesn't work. Please try it and if it works for you let me know.
It will work on PC but in the meantime on mac, it just not working as expected djwizard1. As i already said in the mac forum hopefully this will be fixed in the next released of mac version;)
Regards.
Do the "scan, clean, fix" again. Then rightclick on your library of music and select "delete form searchdb", then right click again and click "add to searchdb". You should be good.
I am trying to delete my library and start over. How do you do this ?? The "crates" does not seem to want to delete
