I have Windows Vista on an HP Laptop and I have been running Virtual DJ With the SL 1 Box for about a year now. I have just switched over to vista from XP and now the SL-1 Box is not showing up on the 64 bit vista system. I have all programs up to date with all drivers up to date. For some reason i am not getting the SL-1 Box as an option for my soundcard? Can anyone help!
geposted Tue 23 Sep 08 @ 10:18 am
Question for you is there 64bit drivers for the card?
geposted Tue 23 Sep 08 @ 11:13 am
Just what I was thinking mate
geposted Tue 23 Sep 08 @ 11:15 am
If you look at the Serato site you will find your answer there.
http://www.serato.com/faq/scratchlive/#1505
http://www.serato.com/search?js=1&mk=&q=SL-1+Windows+Vista+64&fu=&fa=
geposted Tue 23 Sep 08 @ 5:41 pm
You need to install the new 1.8.2 version of serato. before they were not supporting 64 bit. Now they are
geposted Tue 23 Sep 08 @ 8:21 pm
Yeah but for some reason i had to install scratch live in order for the sl-1 box to show up in the virtual dj software. If you just install the driver for the sl-1 box, it will not work in virtual dj?
Unless you can tell me how i am doing it wrong?
geposted Thu 25 Sep 08 @ 4:51 pm
