i got a problem with the hercules rmx the sound works but ! the mixer doesnt work if the crosfader is @ the right chanel you'll just hear the other chanel still playing :S ....i dont know if its a hardware problem but my drivers are al updated .....
geposted Tue 23 Sep 08 @ 4:42 pm
use the WDM instead of ASIO, Check your RMX console settings, Put the VDJ Performance tab at the same rate with the RMx console settings, and Buy the Full Version 5.2.1. GOOD LUCK.
geposted Tue 23 Sep 08 @ 11:35 pm
try this see if it helps, as i say in the vid it may help you, but not everyone's situation...
geposted Wed 24 Sep 08 @ 7:41 am
it didnt work i still have the same problem but if i use the normal vdj it says that there's a asio driver fault
geposted Wed 24 Sep 08 @ 8:58 am
also the volume buttons doest work @ all and i got to set the cue set to get sound of the deck
even if the cross fader is @ the other side so :S
geposted Wed 24 Sep 08 @ 9:00 am
you got the latest djc edition 5.2.1, switch asio to wdm in your rmx pop up window
geposted Wed 24 Sep 08 @ 9:43 am
a\FASDGFSDGADFGASDGF
geposted Wed 10 Dec 08 @ 9:42 am
It looks like your are using the Pro version, so make sure your have the latest update (5.2.1), available from the Download section
First, let's start with the configuration of the Rmx:
- Leave the setting to WDM for now
- Connect your main speakers to output 1/2 at the back of the console, and your headphone to the appropriate output
Launch Virtual DJ, then go to the Sound Setup, and configure as follow:
- Input : None
- Output(s): Headphone
-Soundcard: DJ Console RMX
If you check the box "Apply Eq on Input", you will notice that the Rmx Control Panel switched to ASIO. This is perfectly normal.
At the bottom, you'll also notice a menu that allow you to configure the output channels. Leave it to default "Master Chan1/2 /headphone Chan3/4"
Now, when moving the Crossfader between the two decks should give you a balance of the two songs on your Main speakers 1/2.
For headphone, press the CUE SELECT button for the specific deck you want to hear. You can also use the MON SELECT knob to blend in the Main output to your headphone.
- Input : None
geposted Wed 10 Dec 08 @ 12:51 pm
