Topic: Any Isolators
Im wondering if anyone knows of any good and inexpensive isolators? Nothing like Dope Real, I don't want to spend that kind of cash right now, due to this 1930's depression we're in, know what I mean?
Anyway, I just want somethiing decent to mess around with, 3way would be cool though. So, let me know if you got any ideas,
Thanks in advance
geposted Tue 23 Sep 08 @ 7:42 pm
"I don't want to spend that kind of cash right now, due to this 1930's depression we're in, know what I mean?"
No.... I don't know what you mean, I was not around in the 1930's depression but I give you props for being there and you are still rocking.
LMAO!!!!
Hey Mate no-one told me the 1930s dewhatsit was over. I realy need to take a break from mixin and lift my head up from the desk every once and a while.
Vestax make a nice little unit thats been around for afew years so you might pick up a second had one. As an alternatave if you gan get your hands on a second hand 3way electronic crossover with good control range (normaly used to split up the signals for driving separate bass mid and top cabs) and get a local shop to Knock up a cable to re -combine the separated outputs back into a stereo signal you will have the very same thing as a killer.
One final cheepee alternative would be the Behringer DJX700 mixer which retails new for less than the cost of most killers and has 3 band kill switches and also 3 band kill eqs.
Have fun and dont get too depressed.
It is 2008 after all
DAZ
lol , just an expression people, with this nasty economy right now it sucks! Anyway, good deal Daz im gonna have to check out that Vestax. The mixer would'nt work for me but, good looking out!
Im looking around right now, like I said not looking for top of da line you know? Just something decent enough for home use to sharpen up.
Thanks man!
Nice bit of kit and very usefull for getting rid of earth loops and hum problems but I think what he was looking for was a frequeny isolator/ killer.
DAZ
Yo Caliente, good looking out! But, as Daz said I was looking for a frequency isolator / crossover. Used alot to manipulate house tracks, but thanks bro!
Try this web address. It will show you what the new unit looks like. I think the older one was gold in color but will do the same job. Its half 19" rak width and 1U high so if the recession ever ends you can fit two into your rack without taking up too much space ( 1 for each deck and have some serious fun.) check out ebay and see what you can find.
www.vestax.com/v/products/effectors/dfg-x2.html
Happy hunting
DAZ
@ HKNYC My bad, it thought you meant something else.
