I have a MacBook Pro & I wanted to upgrade the RAM to 4GB. Can you recommend any good sites to buy the RAM or can I just walk into the apple store & buy?
geposted Wed 24 Sep 08 @ 12:25 pm
You can walk into apple store n buy but to me it is a bit expensive. Try your local store.. I'm sure they have a good ones n much cheaper;)
geposted Wed 24 Sep 08 @ 12:34 pm
I have upgrade to 4gb with kingston memory and works fine.
This one "SODIMM KINGSTON 2GB DDR2 667MHZ PC2-5400 KVR667D2S5/2G".
I have paid around 38US$ (26€) here in Spain, because i buy in a dealer.
I think that the normal price it's around 45US$.
I have found it in eBay HERE
Good luck.
Good luck.
geposted Wed 24 Sep 08 @ 1:22 pm
www.newegg.com
geposted Wed 24 Sep 08 @ 2:47 pm
Memory ten dot com
fast shiping
fast shiping
geposted Thu 25 Sep 08 @ 1:54 pm
Newegg had a good price, the local circuit city had them & I have a buddy who works there so I got like $20 off the $99. I just installed them & I notcied a huge diffwerence. I was getting them cause I started using VMware fusion with vista & I noted that the Vista virtual machine was running kinda slow. Now it's perfect. i'm using it to ran acid cause I love it & it doesn't exist on Mac. Bootcamp is good but I hate re-booting.
geposted Thu 25 Sep 08 @ 6:22 pm
Has anyone here started with 2G and upgraded to 4G? If so do you find the performance to be vastly improved or just a little bit? What kind of differences did you notice?
geposted Fri 26 Sep 08 @ 4:36 pm
I like memory form crucial (crucial.com). I've always bought my memory from there and haven't had any problems mixing it with apple's stock memory. Fast shipping and good customer support.
geposted Sat 27 Sep 08 @ 2:14 pm
