Hi there folks.
I have a bunch of mpa files that can't be opened or analysed by VDJ. Yet I can listen to them fine on my computer using my normal mp3 decoder. I tried changing the codecs, telling Virtual DJ to use a different codec to read the mpa files. I ended up trying just about every codec possible in VDJ, to see if any of them could open up an mpa file, to no avail.
I then tried manually changing the song file name from mpa to mp3 and use an mp3 decoder to play the song but no good. VDJ keeps telling me "The file is impossible to open!" and thus it cannot be analysed by VDJ. Yet once out of the VDJ program, I can listen to the song freely on my computer.
Has anyone any ideas on what to do here? Am I missing a codec perhaps and if so, where could it be obtained? Though this doesn't explain why only the Virtual DJ program has problems with them and no where else.
Thanks in advance - bye to all.
Cheers
Barry
Cheers
Barry
geposted Thu 25 Sep 08 @ 2:23 am
What are you using as your "normal" mp3 decoder? Can you open the same file in multiple programs Windows Media Player, WinAmp, and iTunes?
geposted Thu 25 Sep 08 @ 1:06 pm
