Topic: RMX Pitch (+) (-) Problems !!!
Having problems with the RMX Pitch , It seems after loading a song to a deck it takes a while for the pitch to respond.
For example I load a song and right away I CUE and play , I then hit the pitch slider on my RMX and I get no response for about the first 4 seconds or so. I hate it Because sometimes I have to move the pitch slider all the way to + then all the way to get the pitch to respond to me.
If anyone could help or is having the same problem, Please post !
Thanks in advanced !!!
geposted Fri 26 Sep 08 @ 4:33 pm
Are you using the sync button? If so then I'm pretty sure this is a design feature, it locks the pitch, to enable manual pitch control you need to drag the slider.
I have a Total Control which has a little led next to the pitch fader, as soon as you press 'sync' the light goes out to indicate the pitch is locked?
Hope this helps!
