I am tring to install the Hercules dj console mk2 2008 drivers to my laptop, i run the setup, i plug my console when it says to, then a square that says ¨Instaling DJ Console Drivers...¨ start´s to fill but it only gets to 5 squares and then nothing happens...
what should i do?
Intel Pentium
prosessor: 1.86GHz
1 Gb Ram
what should i do?
Intel Pentium
prosessor: 1.86GHz
1 Gb Ram
geposted Sat 27 Sep 08 @ 12:28 am
Sit there and wait, it takes forever and seems like it isnt doing anything, but it is.
geposted Sat 27 Sep 08 @ 12:05 pm
ok, thank´s
i´ll try but it doesnt do a thing, it stays there in 5 squares, i left it the entire night on and nothing happened...
any other sugestions?
geposted Sat 27 Sep 08 @ 2:39 pm
Reinstall from the disc that came with the unit. After that just install the 2008 driver. This should help;)
geposted Sat 27 Sep 08 @ 3:18 pm
i have tried that but when it says to plug the console it doesnt do anything, at least with the 2008 my pc detects the console and starts installing the drivers but then it stays there, doing nothing...
geposted Sat 27 Sep 08 @ 4:00 pm
Vista or XP??
geposted Sun 28 Sep 08 @ 3:57 am
The firmware update have locked the console during the update, you are not the first one :(
Please try to contatc Hercules Support http://ts.hercules.com/
geposted Sun 28 Sep 08 @ 4:06 am
xp
geposted Sun 28 Sep 08 @ 5:25 pm
