Hello,
Im having some issues with this console and i posted the question below to behringer awaiting for a respone.... I figured if I throw something here i might get a response quicker than Behringer so please anything would help.
Im using VDJ 5.2 pro described below
Installing Process:
Download driver for vista> run> follow on screen instructions> control panel relaunch
What happens up to here is that windows installs 2 drivers,
1.Behringer BCD3000 V1.1.6
2. Behringer BCD3000 WDM V1.1.6
Is this correct till now?
Using the controller - Virtual DJ
I use Virtual DJ so i tried to use it on that. Virtual DJ reads the console as BCD2000 instead of 3000 and thats the first. In the remote control section i enable the BCD3000 through software but virtual dj doesnt recognize it
If I select soundcard BCD2000 the software doesnt play
If I select souncard ASIO and BCD3000 it allows to press ASIO config - which pulls up the BCD3000 Control Panel. Still it refuses to play
Traktor 3 LE
Open up the software, preferences audio setup
Audio Device: BCD3000 ASIO
I load song, i press play, the button turns yellow, nothing happens - the song doesnt start
When I turn it to my onboard soundcard the tracks start playing - sound out of my tablet speakers.
I would appreciate it if you can help me as soon as possible
Installing Process:
Traktor 3 LE
geposted Sat 27 Sep 08 @ 11:46 am
Have the same problem on virtual dj 6 with my behringer 3000!
geposted Tue 10 Nov 09 @ 10:08 pm
