Does Virtual DJ Pro have a option to mix music automatically like DJ Twist & Burn, or do I have to mix the music manually myself?
geposted Sat 27 Sep 08 @ 3:43 pm
There is an aoutomated feature that will allow you to set up a playlist and let the program run, segueing from one track to the next. This by no means is a segue that would be acceptable on a dancefloor, but more geared towards cocktail or dinner music, or any application where you just need to provide simple background music. The segue is pretty intelligent, in that you can select mix points (which are remembered for the next time) and the crossfade length, but again this is just a simple fade from one track to the next. NOT beatmixed. Pretty much the way itunes fades from one song to the next in the list.
geposted Sun 28 Sep 08 @ 3:32 am
Sounds like you want mixmeister.
geposted Sun 28 Sep 08 @ 6:23 am
How do you set up and start a playlist of songs to play and mix automatically, for cocktail or dinner hour? Is there a way to "forward" or "segue" out of a song in that playlist and on to the next song?
geposted Sun 11 Dec 11 @ 7:23 pm
Three year old thread...locked..
geposted Sun 11 Dec 11 @ 9:22 pm
