I've downloaded some skins from the ''downloads'' sections.
When I double-click the .exe file, i get an error saying that I have to install the software first (VDJ DJC Edition is installed and works fine).
I've extracted the .exe files and manualy copied the .zip file in the ''skins'' folder, but when I select them through VDJ, I get an error saying ''invalid skin, error in XML line #''
How can I fix those problems and install skins on VDJ DJC Edition?
geposted Sat 27 Sep 08 @ 4:49 pm
Yeah, I'm having the exact same problem. Any idea how to fix this?
geposted Sun 28 Sep 08 @ 3:28 pm
Why nobody replies? Please people! Could Vista be the problem?
geposted Mon 29 Sep 08 @ 9:57 am
I have the same problem...
geposted Sun 19 Jun 11 @ 10:25 am
The skin cannot be changed for VDJ LE.
As for the old DJC version (original DJ Console, DJ Console MK2) I believe that if the skins have been created for later versions, you won't be able to use them.
geposted Mon 20 Jun 11 @ 7:43 am
As mentioned, the LE version of the software does not support skin changes. Skin downloads are only available to Broadcaster, Pro Basic and Pro Full users.
If you would like to download and install skins, please consider supporting the software and purchasing it here: https://virtualdj.com/buy/
geposted Mon 20 Jun 11 @ 10:00 am
