Topic: xp or vista
My new laptop came with vista but i think djdecks and other audio software will run better with XP. What do you guys think?
thin king about installing xp.
I have 2 gigs of ram, 1.8 ghz proc
geposted Sun 28 Sep 08 @ 4:37 pm
single or duel core? and XP all the way!!! vista just hogs the processor n i hate it! (n i know a lot about computers n software n have even worked in the industory before) compared to XP anyway if you need fast processor and the power i would recomend XP by far maby i just hate vista but personally i love XP n if u can try installing both (only if u know what ur doing tho n use a serpate partition) and see whats quicker my bets defintly on XP!
DJ software works best with XP. Its more stable and more Latency. Vista Is now getting better compared to when it first cam out.
single core
It is a celeron proc. Not a very high-end machine but it was designed to be used with vista.
Hopefully i can find appropriate drivers.
I am going to give xp a try on it.
thank for your input
Vista all the way now, for me
The problem with XP is that all the newer higher power video cards that can do the beautiful DirectX 10 3D effects only have drivers for VISTA. So if you have XP with a pretty new video card, you will be limited on transitions and effects.
nearly two years with vista for me, wouldn't change it now...
Is there a difference in Vista 16 or 32 bit? Anyway go with Mac, LOL just that's what I use for now.
DJ Matt
It can really depend on your set up. I have the Denon HS-5500 and the MIDI connections do not work very well in Vista. I ended up making my laptop dual boot and switching to XP for VDJ.
Taipanic
