Topic: Anyone Please Help
Hello I have been looking forward to downloading this program and have heard a lot of good things, but wanted to try it out so I downloaded the 20 trial version. No matter what I have tried I cannot seem to be able to run the program properly. I am running a Dell Inspiron E1505 with Windows Vista Intel Core Duo 2.0 Ghz; 2GB of Ram; 2 Numark TTX with Virtual DJ Vinyl and a Maya USB 44 Soundcard.
My problem is that first of all I am running the Timecoded Vinyls and they never seem to stay on beat, there is always either a drag or a skip that greatly disturbs the mix, it is not smooth. Secondly there are points where I lose control of the song and cannot manipulate it with the vinyl anymore. I have already tried changing the pitch sensitivity as I had read in other forums but still no luck.
I have tried to search blogs and forums to help me with the problems but cannot seem to find anything. Please I want to buy the program but am scared that if I do, the same problems will occur. If you can please help me out to fix this I would feel 100% sure that my purchase would be worth it.
Thank You.
Dave Hopkins
geposted Mon 29 Sep 08 @ 1:42 am
Well, when I downloaded the TRIAL version, I also had problems, After investing into VDJ and making the purchase I was able to downloand the FULL workig software. all the problem went away. I am unsing Timecodes with X-Session Pro for video crossfader, DAC-2, and my SL1210MK2s. with Rane MP2 Mixer.
No problems on both a Pentuim 4 PC with 256 MB ram and 80GB HD, I know, I know
an the Laptop, Dual core P4 1.0 GB MEM 700 GB HD,
no problems, Full time code signal using Maya 44 USB.
So do you think that it is because of the TRIAL version of the software? What if it keeps happening when I buy the product?
Hi Dave,
The trial version is limited and does not support timecode.
I have been using VDJ for 4 years and IT'S WORTH IT!!!
You need to purchase the Pro VDJ. All your issues will go away and you will get all the support you may need as well as access to EVERYTHING VDJ has to offer including updates.
Minor correction City, the trial only supports time codes for ten minutes.... ;-)
